1 Choose Stat > Regression > Stability Study > Stability Study.
2 In Response, enter the column that contains the response data.
3 In Time, enter the column that indicates when each observation was recorded.
4 If your data are from multiple batches, enter the column that indicates the batch for each observation, in Batch.
5 Do one or both of the following:
6 If you like, use any dialog box options.
7 Click OK.
