Example of Trend Analysis
You collect employment data in a trade business over 60 months and wish to predict employment for the next 12 months. Because there is an overall curvilinear pattern to the data, you use trend analysis and fit a quadratic trend model. Because there is also a seasonal component, you save the fits and residuals to perform decomposition of the residuals (see Example of Decomposition).
1    Open the worksheet EMPLOY.MTW.
2    Choose Stat > Time Series > Trend Analysis.
3    In Variable, enter Trade.
4    Under Model Type, choose Quadratic.
5    Check Generate forecasts and enter 12 in Number of forecasts.
6    Click Storage.
7    Check Fits (Trend Line), Residuals (detrended data), and Forecasts. Click OK in each dialog box.
Session Window Output
Trend Analysis for Trade
Data      Trade
Length    60
NMissing  0
Fitted Trend Equation
Yt = 320.76 + 0.509×t + 0.01075×t^2
Accuracy Measures
MAPE   1.7076
MAD    5.9566
MSD   59.1305
Forecasts
Period  Forecast
61       391.818
62       393.649
63       395.502
64       397.376
65       399.271
66       401.188
67       403.127
68       405.087
69       407.068
70       409.071
71       411.096
72       413.142
Graph window output
Interpreting the results
The trend plot that shows the original data, the fitted trend line, and forecasts. The Session window output also displays the fitted trend equation and three Measures of Accuracy to help you determine the accuracy of the fitted values: MAPE, MAD, and MSD. The trade employment data show a general upward trend, though with an evident seasonal component. The trend model appears to fit well to the overall trend, but the seasonal pattern is not well fit. To better fit these data, you also use decomposition on the stored residuals and add the trend analysis and decomposition fits and forecasts (see Example of decomposition).
