Analyze Factorial DesignTwo-Level Split-Plot Designs |
Use the p-values (P) in the analysis of variance table to determine which of the effects in the model are statistically significant. Typically you look at the interaction effects in the model first because a significant interaction will influence how you interpret the main effects. To use the p-value, you need to:
- if the p-value is less than or equal to a, conclude that the effect is significant.
- if the p-value is greater than a, conclude that the effect is not significant.
Coded Coefficients
Term Effect Coef SE Coef T-Value P-Value VIF Constant 50.875 0.811 62.70 0.000 Pretreatment[HTC] -8.050 -4.025 0.811 -4.96 0.008 * Stain -0.050 -0.025 0.739 -0.03 0.975 1.00 Pretreatment[HTC]*Stain 4.483 2.242 0.739 3.03 0.039 1.00 |
For the water resistance data, the table shows the following:
