Analyze Factorial DesignTwo-Level Split-Plot Designs |
Look at the Effect to determine the relative strength of the effects.
- For main effects, a positive sign indicates that the high factor setting results in a higher response than the low setting.
- For main effects, a negative sign indicates that the low factor setting results in a higher response than the high setting.
Coded Coefficients
Term Effect Coef SE Coef T-Value P-Value VIF Constant 50.875 0.811 62.70 0.000 Pretreatment[HTC] -8.050 -4.025 0.811 -4.96 0.008 * Stain -0.050 -0.025 0.739 -0.03 0.975 1.00 Pretreatment[HTC]*Stain 4.483 2.242 0.739 3.03 0.039 1.00 |
For the water resistance data, the effects suggest the following:
