Acceptance Sampling by Attributes - CompareSampling Criteria - Lot Size |
There are a few things to consider when choosing a lot or batch size for sampling. Typically, people choose a lot size that is convenient for shipping and handling for both the supplier and consumers. For example, an entire shipment may make up a lot size. Because sampling plans assume homogeneity of parts in a given lot, the units that comprise a lot should be produced under the same processing conditions. Also, larger lots are generally more economical to inspect than a series of smaller lots.
Measurement type: Go/no go Lot quality in percent defective Lot size: 25000 Use the binomial distribution to calculate probability of acceptance |
For the grocery bags, a shipment of 25000 bags is received every few days.
