Acceptance Sampling by Variables - Compare
Sampling Criteria - Lot Size
There are a few things to consider when choosing a lot or batch size for sampling. Typically, people choose a lot size that is convenient for shipping and handling for both the supplier and consumers. For example, an entire shipment may make up a lot size. Because sampling plans assume homogeneity of parts in a given lot, the units that comprise a lot should be produced under the same processing conditions. Also, larger lots are generally more economical to inspect than a series of smaller lots.
Example Output
Lot quality in defectives per million
Lower Specification Limit (LSL)         0.395
Upper Specification Limit (USL)         0.415
Lot Size                                3600
Interpretation
For the camera data, lenses come in lots of 3600.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
