Generalized Variance ChartSummary |
Use generalized variance charts to determine whether or not the joint process variability for two of more variables is in control.
Generalized variance charts allow you to simultaneously monitor whether the joint variability of two or more related variables is in control.
Data Description |
A plastics company wants to track the process variability of tear strength, glossiness, and opacity of sheets of plastic. You collect 4 samples over 10 days. These variables are correlated, so you decide to create a generalized variance control chart to monitor the joint variability.
Data: PlasticSheets.MTW (available in the Sample Data folder).
