Generalized Variance ChartTest Results - Test Results |
The test results indicate points that are beyond the control limits. A failed point indicates that a nonrandom pattern exists in the data that may be the result of special-cause variation. You should investigate these points.
Test Results for Generalized Variance Chart
TEST. One point beyond control limits. Test Failed at points: 6 |
For the plastics data, the test results indicate that subgroup 6 falls outside of the control limits. Investigate why this point is out of control.
