Capability Sixpack - Between/Within
Graphs - Standard Deviations
The StDevs are located in the lower center of the Capability Sixpack - Between/Within.
The standard deviation section consists of the following:
·    Overall standard deviation - a measure of the variation of all the measurements.
·    Between standard deviation - a measure of the variation between subgroups.
·    Within standard deviation - a measure of the variation within subgroups.
·    Between/Within standard deviation - a measure of the between/within standard deviation, calculated by combining the between-subgroup and within-subgroup variation.
Example Output
Interpretation
For the coating data:
·    Overall standard deviation - The overall standard deviation is 0.8385.
·    Between standard deviation - The between standard deviation is 0.6855.
·    Within standard deviation - The within standard deviation is 0.4061.
·    Between/Within standard deviation - The between/within standard deviation is 0.7967.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
