Individual Distribution Identification
Data Fitted with 14 Distributions and 2 Transformations - Transformations
Minitab transforms your data to follow a normal distribution using Box-Cox and Johnson transformations. The session output window includes the following transformation details:
·    For the Box-Cox transformation, an optimal value of lambda.
·    For the Johnson transformation, the function used to transform the data.
Example Output
Box-Cox transformation: Lambda = -5.00000
Johnson transformation function:
0.804604 + 0.893699 * Ln( ( X - 46.2931 ) / ( 59.8636 - X ) )
Interpretation
For the calcium data:
·    The optimal value of lambda for the Box-Cox transformation is 5.00000.
·    The Johnson transformation uses this function to transform the data: 0.804604 + 0.893699 * Ln( ( X - 46.2931 ) / ( 59.8636 - X ) ).
