Individual Distribution IdentificationData Fitted with 14 Distributions and 2 Transformations - Goodness-Of-Fit Tests |
The goodness-of-fit test includes Anderson-Darling test statistics (AD), corresponding p-values (P), and likelihood ratio test p-values to assess whether a distribution fits your data.
You can use Anderson-Darling test to examine whether a chosen distribution fits your data well.
Use the p-value (P) to determine which distribution fits your data well:
1 Identify the p-value for the distribution you want to evaluate.
2 Compare the p-value to your a-level. A commonly used a-level is 0.05.
For several distributions, Minitab offers the standard version as well as a version with an extra parameter. In these cases, use the LRT P to determine whether adding the extra parameter significantly improves the fit over the distribution without the extra parameter. A LRT P value less than 0.05 suggests that the improvement is significant.
The LRT P value is also useful for 3-parameter distributions for which there is no established method for calculating the p-value. In these cases, it is advisable to first examine the p-value for the corresponding two-parameter distribution. Then look at the LRT P for the 3-parameter distribution to determine whither the three-parameter distribution is significantly better than the two-parameter distribution. However, it may be advisable to choose a distribution which has a calculated p-value and a similar AD value.
Goodness of Fit Test
Distribution AD P LRT P Normal 0.754 0.046 Box-Cox Transformation 0.398 0.353 Lognormal 0.650 0.085 3-Parameter Lognormal 0.341 * 0.017 Exponential 20.614 <0.003 2-Parameter Exponential 1.684 0.014 0.000 Weibull 1.442 <0.010 3-Parameter Weibull 0.230 >0.500 0.000 Smallest Extreme Value 1.656 <0.010 Largest Extreme Value 0.394 >0.250 Gamma 0.702 0.071 3-Parameter Gamma 0.268 * 0.006 Logistic 0.726 0.034 Loglogistic 0.659 0.050 3-Parameter Loglogistic 0.432 * 0.027 Johnson Transformation 0.124 0.986 |
Goodness-of-fit statistics for the Box-Cox transformation (AD = 0.398, P = 0.353) and the Johnson transformation (AD = 0.124, P = 0.986) suggest that a normal distribution is a good fit for both methods of transformed calcium data. The 3-parameter Weibull distribution (AD = 0.230 and P > 0.500) fits the data well.
The LRT P values for the 3-parameter lognormal (0.017), 3-parameter Weibull (0.000), 3-parameter gamma (0.006), and 3-parameter loglogistic (0.027) suggest that these distributions significantly improve the fit compared to their 2-parameter counterparts.
The goodness-of-fit test results for the 14 distributions and 2 transformations suggest that more than one distribution results in a p-value greater than 0.05. The 3-parameter Weibull (P > 0.500), the largest extreme value (P > 0.250), Box-Cox transformation (P = 0.353) and Johnson transformation (P = 0.986) fit the calcium data better than the other distributions.
Among extremely close p-values, select either a distribution:
Choose the one that is most conservative.
