Individual Distribution Identification
Data Fitted with 14 Distributions and 2 Transformations - Maximum Likelihood Estimates
Maximum likelihood (ML) estimates are calculated by maximizing the likelihood function for each distribution being considered. For each set of distribution parameters, the likelihood function describes the chance that the true distribution has these parameters based on the sample.
Example Output
ML Estimates of Distribution Parameters
Distribution             Location      Shape     Scale  Threshold
Normal*                  50.78200              2.76477
Box-Cox Transformation*   0.00000              0.00000
Lognormal*                3.92612              0.05368
3-Parameter Lognormal     1.69295              0.46849   44.74011
Exponential                                   50.78200
2-Parameter Exponential                        4.06326   46.71873
Weibull                             17.82470  52.13681
3-Parameter Weibull                  1.47605   4.53647   46.66579
Smallest Extreme Value   52.22257              2.95894
Largest Extreme Value    49.50370              2.16992
Gamma                              351.04421   0.14466
3-Parameter Gamma                    2.99218   1.63698   45.88376
Logistic                 50.57182              1.59483
Loglogistic               3.92259              0.03121
3-Parameter Loglogistic   1.54860              0.32763   45.46180
Johnson Transformation*   0.02897              0.97293
* Scale: Adjusted ML estimate
Interpretation
For the calcium data, the shape, scale, and threshold parameter estimates for the 3-parameter Weibull distribution are 1.47605, 4.53647, and 46.66579.
