Zone ChartTest results - Test Results |
The Zone chart assesses whether the process is in control. Each time the points cross the center line, the cumulative score is set to zero. Each cumulative score helps determine whether or not the process is in control. When the cumulative score equals or exceeds 8, the process is out-of-control.
Test Results for Zone Chart
TEST. Cumulative score greater than or equal to zone 4 score. Test Failed at points: 5, 10 |
For the steel bar process data, subgroups 5 and 10 exceeded a cumulative score of 8.
