Analysis of MeansSummary |
Analysis of Means (ANOM), a graphical analog to ANOVA, tests the equality of population means. You can use ANOM with one or two factors, though two-factor designs must be balanced.
Minitab displays a graph, similar to a control chart, that shows how the mean for each level of a factor compares to the overall mean (also called the grand mean). Minitab flags means that are significantly different from the overall mean. ANOM, therefore, tells you when the level means differ and what those differences are.
As with analysis of variance, you can use ANOM if you can assume that the response approximately follows a normal distribution. In addition, you can use special versions of ANOM when your response consists of proportions (binomial data) and counts (Poisson data). With binomial data, the sample size (n) must be constant.
ANOM uses a normal approximation with both binomial and Poisson data. With binomial data, both np and n(1-p) should be at least 5. With Poisson data, the mean should be at least 5. |
Data Description |
Analysis of Means uses four data sets:
A study compared experienced and inexperienced drivers on three types of roads. The two factors are:
A tester recorded the number of steering corrections each driver made on each type of road. The response variable is Corrects.
A tester took 11 samples, each consisting of 80 welds. In each sample, he recorded the number of welds that did not meet specifications.
The manager of a food packing company wants to monitor the number of overfilled containers for each of the packing machines. She counts the number of overfilled containers per machine on the same day.
Data: Driving.MTW, Packing.MTW, Weld.MTW, WineTaste.MTW (available in the Sample Data folder).
