Use the ANOM main effects plot to test
the hypothesis that each factor level mean is equal to the overall mean
at an a-level
you specify. Minitab displays one main effect plot for each factor in
a two-way design. The main effects plot shows the following:
· Plotted
points –
the sample means at each factor level.
· Center
line (green) –
the overall mean.
· Lower
and upper decision limits (red) –
used to test the hypothesis. Minitab looks for sample means located beyond
the decision limits and marks them with a red symbol.
- If
a sample mean is located beyond a decision limit, you can reject the hypothesis
that the mean is equal to the overall mean.
- If
a sample mean falls within the decision limits, you cannot reject the
hypothesis that the mean is equal to the overall mean.
The driving data contains two factors,
Driving Experience and RoadType. The main effects plots indicate the following:
· The
overall mean is 12.917, which is the center
line in both graphs.
· The
sample means for both levels of Experience are beyond the decision limits.
Therefore, you can reject the hypothesis that the means for Experience
are equal to the overall mean. The means for both Experience 1 and Experience
2 differ from the overall mean.
· The
sample means for two levels of RoadType are beyond the decision limits.
Therefore, you can reject the hypothesis that the means for RoadType are
all equal to the overall mean. In fact, the means for RoadType 1 and RoadType
3 differ from the overall mean.
