One-Sample Equivalence TestTest |
In addition to the confidence interval (CI) for the difference, Minitab also performs a hypothesis test. If you use the default method to calculate the CI, then both the test and the CI lead to the same conclusion about claiming equivalence.
The results for the hypothesis test include p-values for two separate null hypotheses:
If both null hypotheses are rejected, then the difference falls within your equivalence interval and you can claim that the product or process mean is equivalent to the target value.
Test
Null hypothesis: Difference ≤ -0.42 or Difference ≥ 0.42 Alternative hypothesis: -0.42 < Difference < 0.42 α level: 0.05
Null Hypothesis DF T-Value P-Value Difference ≤ -0.42 27 5.0972 0.000 Difference ≥ 0.42 27 -0.97605 0.169
The greater of the two P-Values is 0.169. Cannot claim equivalence. |
For the snack bag analysis, the highest p-value is 0.169, which is greater than the a level of 0.05. These results indicate that the difference is not within your equivalence limits of -0.42 and 0.42. Thus you cannot claim that the force that is required to open the new bags is equivalent to the target value.
