Orthogonal RegressionPrediction - Predicted Values |
Minitab displays the predicted value table when you request the prediction of new response values at certain settings of the predictors.
Predicted Values for New Observations
Predicted New Obs Standard New StDev 1 80 79.9883 1.74021 |
For the glucose data, the researchers want to predict the glucose reading for the new method when the standard method gives a reading of 80. The predicted value is 79.9883, which is essentially identical to the reading using the standard method.
