Partial Least Squares
Predicted Response Tables - Confidence Interval
Minitab displays a confidence interval for each predicted response, providing a range within which you can expect the estimated mean response to fall.
Example Output
Predicted Response for New Observations Using Model for Moisture
Row      Fit    SE Fit        95% CI              95% PI
  1  14.5184  0.388841  (13.7343, 15.3026)  (12.5910, 16.4459)
  2   9.3049  0.372712  ( 8.5532, 10.0565)  ( 7.3904, 11.2193)
  3  14.1790  0.504606  (13.1614, 15.1966)  (12.1454, 16.2127)
  4  16.4477  0.559704  (15.3189, 17.5764)  (14.3562, 18.5391)
  5  15.1872  0.358044  (14.4652, 15.9093)  (13.2842, 17.0903)
  6   9.4639  0.485613  ( 8.4846, 10.4433)  ( 7.4492, 11.4787)
Test R-sq: 0.906451
Predicted Response for New Observations Using Model for Fat
  1  18.7372  0.378459  (17.9740, 19.5004)  (16.8612, 20.6132)
  2  15.3782  0.362762  (14.6466, 16.1098)  (13.5149, 17.2415)
  3  20.7838  0.491134  (19.7933, 21.7743)  (18.8044, 22.7632)
  4  14.3684  0.544761  (13.2698, 15.4670)  (12.3328, 16.4040)
  5  16.6016  0.348485  (15.8988, 17.3044)  (14.7494, 18.4538)
  6  20.7471  0.472648  (19.7939, 21.7003)  (18.7861, 22.7080)
Test R-sq: 0.762701
Interpretation
In this example, the scientists requested a 95% confidence interval. They can be 95% confident that, for the first sample, for all observations with that set of predictor values, the mean response for moisture will be between 13.7343 and 15.3026.
Calendar with week numbers
US Federal Holidays
Australia Public Holidays
