Partial Least SquaresPredicted Response Tables - Prediction Interval |
Minitab displays a prediction interval for each predicted response, providing a range within which you expect the predicted response for a single sample to fall.
The prediction interval is always wider than the confidence interval because of the added uncertainty involved in predicting an individual response.
Predicted Response for New Observations Using Model for Moisture 1 14.5184 0.388841 (13.7343, 15.3026) (12.5910, 16.4459) 2 9.3049 0.372712 ( 8.5532, 10.0565) ( 7.3904, 11.2193) 3 14.1790 0.504606 (13.1614, 15.1966) (12.1454, 16.2127) 4 16.4477 0.559704 (15.3189, 17.5764) (14.3562, 18.5391) 5 15.1872 0.358044 (14.4652, 15.9093) (13.2842, 17.0903) 6 9.4639 0.485613 ( 8.4846, 10.4433) ( 7.4492, 11.4787) Test R-sq: 0.906451
Predicted Response for New Observations Using Model for Fat 1 18.7372 0.378459 (17.9740, 19.5004) (16.8612, 20.6132) 2 15.3782 0.362762 (14.6466, 16.1098) (13.5149, 17.2415) 3 20.7838 0.491134 (19.7933, 21.7743) (18.8044, 22.7632) 4 14.3684 0.544761 (13.2698, 15.4670) (12.3328, 16.4040) 5 16.6016 0.348485 (15.8988, 17.3044) (14.7494, 18.4538) 6 20.7471 0.472648 (19.7939, 21.7003) (18.7861, 22.7080) Test R-sq: 0.762701 |
In this example, the scientists requested a 95% prediction interval. They can be 95% confident that, for the first sample, the actual response for moisture will be between 12.5910 and 16.4459.
