Stability StudyMethod and Factor Information |
The method table includes information about missing data and about the Box-Cox transformation if you perform one.
The factor information table includes the name of the batch factor, the type of batch factor, and the number of batches.
Method
Rows unused 5
Factor Information
Factor Type Number of Levels Levels Batch Fixed 5 1, 2, 3, 4, 5 |
The response column for the pill data contains 5 missing values.
The Batch column contains the batch information. Batch is a fixed factor that has 5 levels. The batches are numbered 1 through 5.
