Stability Study
Model Selection
If your data include a batch factor, then the model selection table shows the results of the model selection process. Minitab uses the final model from the selection process to estimate shelf life.
Minitab starts with the full model that includes time, batch, and the batch by time interaction. Minitab then compares the p-value for the interaction to the value specified in Alpha for pooling batches (also called a). If the p-value for the interaction is less than a, then the model cannot be reduced. The final model includes all three terms.
If the p-value for the interaction is greater than or equal to a, then Minitab removes the interaction and evaluates the reduced model with only time and batch. If the p-value for batch in the reduced model is less than a, then the model cannot be reduced further. The final model includes time and batch.
If the p-value for batch in the reduced model is greater than or equal to a, then Minitab removes batch. The final model includes only time.
Example Output
Model Selection with α = 0.25
Source       DF   Seq SS   Seq MS  F-Value  P-Value
Month         1  122.460  122.460   345.93    0.000
Batch         4    2.587    0.647     1.83    0.150
Month*Batch   4    3.850    0.962     2.72    0.048
Error        30   10.620    0.354
Total        39  139.516
Terms in selected model: Month, Batch, Month*Batch
Interpretation
For the pill data, the p-value for the Month by Batch interaction (Month*Batch) is 0.048. Because the p-value is less than the a-level of 0.25, the model cannot be reduced.
