Stat > Quality Tools > Acceptance Sampling by Variables > Accept / Reject Lot
Allows you to determine whether to accept or reject an entire lot (batch) of product, based on your sample data.
Measurement data: Enter a column of sample measurements. You can only evaluate one column of data at a time.
Critical distance (k value): Enter a value to represent the critical distances from the mean that should not be exceeded with some degree of certainty.
Lower spec: Enter the lower specification limit. You must enter at least one specification limit.
Upper spec: Enter the upper specification limit. You must enter at least one specification limit. The upper spec must be greater than the lower spec.
Historical standard deviation (Optional): Enter a known value for the sample standard deviation.
