Stat > Quality Tools > Capability Sixpack > Normal > Estimate
Allows you to specify the method for estimating the population standard deviation.
You can set preferences for the estimation of s using Tools > Options > Control Charts and Quality Tools > Estimating Sigma.
If you select the Johnson transformation, these estimation options are ignored because Minitab is unable to estimate the within subgroup variation. |
Whether Minitab displays an R chart or an S chart depends on the size of the subgroups. If more than 50% of the subgroups are the same size, then the most common subgroup size determines the chart. Otherwise, the largest subgroup size determines the chart. If the subgroup size is 8 or less, Minitab displays an R chart. If the subgroup size is 9 or more, Minitab displays an S chart. If the subgroup size is 1, Minitab displays a moving range chart.
Methods of estimating within subgroup standard deviation
Capability Statistics: Choose an estimate of the within-subgroup standard deviation for the capability statistics.
(for subgroup size > 1)
Rbar: Use the average of the subgroup ranges.
Sbar: Use the average of the subgroup standard deviations.
Pooled standard deviation: Use a pooled standard deviation.
(for subgroup sizes = 1)
Average moving range: Use the average of the moving range.
Median moving range: Use the median of the moving range.
Square root of MSSD: Use the mean squared successive differences.
Control Charts: Choose an estimate of the within-subgroup standard deviation for the control charts
(for 1< subgroup size <= 8)
(for subgroup size > 8)
(for subgroup size = 1) Minitab generally estimates standard deviation using the sample standard deviations or ranges of each subgroup. But when the subgroup size is 1 you cannot calculate sample standard deviations or ranges. Minitab estimates standard deviation using moving ranges instead.
Use unbiasing constants to calculate standard deviations
Within subgroup: Check to estimate within-subgroup standard deviation using unbiasing constants.
Overall (capability statistics only): Check to estimate the overall standard deviation using unbiasing constants.
Use moving range of length: Enter the number of observations used to calculate the moving range. By default, a span of 2 is used as consecutive values have the greatest chance of being alike.
