Stat > Quality Tools > Capability Sixpack > Normal
Use to produce process capability report when your data follow a normal distribution.
To confirm process stability, the report includes:
To confirm normality, the report includes:
To assess capability, the report includes:
You can also use this feature to correct nonnormality in your data using a Box-Cox or Johnson transformation, then perform capability on the transformed data.
A model that assumes the data are from a normal distribution suits most process data. If your data are either very skewed or the within-subgroup variation is not constant (for example, when this variation is proportional to the mean), see Nonnormal data.
Data are arranged as
Single column: Choose if data is in one column. Enter a column.
Subgroup size (use a constant or an ID column): Enter the subgroup size (for equal-size subgroups) or a column of subscripts (for unequal-size subgroups). If the subgroups are not equal, the control limits will not be straight lines but will vary with the subgroup size.
Subgroups across rows of: Choose if subgroups are arranged in rows across several columns. Enter the columns.
If you select the Johnson transformation, subgroup sizes are only used for the process charts. |
Lower spec: Enter the lower specification limit.
Upper spec: Enter the upper specification limit.
You must enter at least a lower spec and/or upper spec. |
Historical mean (optional): Enter a value for the mean of the population distribution if you have a known process parameter or an estimate obtained from past data. If you do not specify a value for the mean, it is estimated from the data.
Historical standard deviation (optional): Enter a value for standard deviation of the population distribution if you have a known process parameter or an estimate obtained from past data. If you do not specify a value for standard deviation, it is estimated from the data. See <Estimate> for estimation options.
You cannot use historical parameters if you transform the data. |
