Stat > Quality Tools > Capability Sixpack > Normal > Tests
Lets you select a subset of the eight tests for special causes. Each test detects a specific pattern in the data plotted on the chart. The occurrence of a pattern suggests a special cause for the variation, one that should be investigated.
You can set preferences for the tests to perform and for the sensitivity of these tests using Tools > Options > Control Charts and Quality Tools > Tests.
When a point fails a test, Minitab marks it with the test number on the plot. If a point fails more than one test, Minitab marks it by the lowest numbered test, and prints a summary table with complete information in the Session window.
Subgroup sizes must be equal to perform the tests.
Tests For Special Causes (default definitions)
Perform all eight tests: Choose to perform all eight tests for special causes.
Choose specific tests to perform: Choose to specify a subset of the eight tests, then check any combination of the tests listed below.
One point more than 3 standard deviation from center line
Nine points in a row on same side of center line
Six points in a row, all increasing or all decreasing
Fourteen points in a row, alternating up and down
Two out of three points more than 2 standard deviation from center line (same side)
Four out of five points more than 1 standard deviation from center line (same side)
Fifteen points in a row within 1 standard deviation of center line (either side)
Eight points in a row more than 1 standard deviation from center line (either side)
