When you have nonnormal data, you can either transform the data in such a way that the normal distribution is a more appropriate model, or choose a nonnormal probability model for the data.
- Box-Cox power transformation, use Individual distribution identification, Capability Analysis (Normal), Capability Analysis (Between/Within), Capability Sixpack (Normal), Capability Analysis Multiple Variables (Normal), and Capability Sixpack (Between/Within)
- Johnson transformation, use Johnson transformation, Capability Analysis (Nonnormal), Capability Analysis Multiple Variables (Nonnormal), and Capability Sixpack (Nonnormal).
This table summarizes the differences between the models.
Normal model |
Nonnormal model |
Uses actual or transformed data for the histogram |
Uses actual data units for the histogram |
Calculates within, between/within (when both within and between subgroup variation exists), and overall capability |
Calculates only overall capability |
Draws a normal
curve over the histogram to help you determine whether the transformation
made the data |
Draws the chosen nonnormal distribution curve over the histogram to help you determine whether the data fits the specified distribution |
Which method is better? The only way to answer that question is to see which model fits the data better. If both models fit the data about the same, it is probably better to choose the normal model, since it provides estimates of both overall and within process capability.
