Individual Distribution Identification
overview
     how to     example     data     see also
Stat > Quality Tools > Individual Distribution Identification
Use to evaluate the optimal distribution for your data based on the probability plots and goodness-of-fit tests prior to conducting a capability analysis study. Choose from 14 distributions.
You can also use distribution identification to transform your data to follow a normal distribution using a Box-Cox transformation or a Johnson transformation.
Data are arranged as
Single column: Choose if data are in one column, then enter a column.
Subgroup size: Enter a number or column of subscripts to specify subgroup sizes.
Subgroups across rows of: Choose if subgroups are arranged in rows across several columns, then enter the columns.
Use all distributions and transformations: Choose to fit your data with each of the 14 parametric distributions and the 2 transformations.
Specify: Choose to specify one to four distributions or transformations to fit your data.
Distribution 1: Check to fit a distribution (default is Normal), then select a distribution of your choice.
Distribution 2: Check to fit a distribution (default is Exponential), then select a distribution of your choice.
Distribution 3: Check to fit a distribution (default is Weibull), then select a distribution of your choice.
Distribution 4: Check to fit a distribution (default is Gamma), then select a distribution of your choice.
<Box-Cox>
<Johnson>
<Options>
<Results>
