Stat > Quality Tools > Individual Distribution Identification > Johnson
Use a Johnson transformation to transform your data to follow a normal distribution and store the transformed data for further analysis. Minitab performs the Johnson transformation by default or when you choose Johnson transformation from the drop-down list of distributions.
By default, Minitab uses a p-value of 0.10 to select the best fit; however, you may choose any value between 0 and 1.
If the Johnson transformation does not adequately transform your data, the Box-Cox transformation may work better; use whichever normal transformation method works better for your data.
P-value to select best fit: Enter a p-value for selecting the best transformation. The default is 0.10.
Store transformed data in
Single columns: Choose to store data in one column, then enter a column.
Subgroups across rows of: Choose to store data in subgroups arranged in rows across several columns, then enter the columns
