Stat > Quality Tools > Individual Distribution Identification > Options
Use to control the display of the graphical output.
You can set preference for Y-scale type, graph orientation, and a method for calculating the plot points using Tools > Options > Individual Graphs > Probability Plots.
Display one probability plot per graph: Check to display one probability plot per graph window. The default is to display four probability plots per graph window.
Do not display confidence intervals on probability plots: Check to display probability plots without confidence intervals.
Confidence levels: Enter a confidence level between 0 and 100.
