Stat > Quality Tools > Individual Distribution Identification > Results
Use to control the display of the Session window output.
Descriptive statistics: Check to display descriptive statistics for the data.
Goodness of fit tests: Check to display goodness-of-fit tests results for each distribution chosen in the main dialog box.
Distribution parameter estimates: Check to display distribution parameters estimated from the data.
Percentiles for these percents: Check to estimate percentiles for selected percents, then enter the percents (0 < P < 100) individually or as a column. 0.135, 0.5, 1, 2, and 5 are the default percents.
