Process Capability for Attributes Data
overview
You can produce process capability studies for either binomial or Poisson
data.
Binomial data
Binomial data is usually associated with recording the number of defective
items out of the total number of items sampled. For example, if you are
a manufacturer, you might have a go/no-go gauge that determines whether
an item is defective or not. You could then record the number of items
that were failed by the gauge and the total number of items inspected.
If you are an assembler, you could record the number of parts sent back
due to poor fit in the assembly process and the total number of parts
purchased. Or, you could record the number of people who call in sick
on a particular day, and the number of people scheduled to work that day.
These examples could be modeled by a binomial distribution if the following
conditions are met:
· Each
item is the result of identical conditions.
· Each
item can result in one of two possible outcomes ("success/failure",
"go/no-go," etc.).
· The
probability of a success (or failure) is constant for each item.
· The
outcomes of the items are independent
of each other.
Poisson data
Poisson data is usually associated with the number of defects observed
in an item, where the item occupied a specified amount of time or a specified
space. Because the sizes of the items may vary, you may want to keep track
of each item's size. Here are some examples:
· If
you manufacture electrical wiring, you may want to record the number of
breaks in a piece of wire. The lengths of the pieces may vary, so you
may also want to record the length for each piece of wire.
· Or,
if you manufacture appliances, you may want to record the number of scratches
on one of the surfaces of the appliance. The size of the surfaces may
be different for different appliances, so you may want to record the size
of each surface sampled.
· Or,
you may record the number of errors in billing statements. The billing
statements may be considered to be the "same size," because
they have the same number of opportunities for errors, so you do not have
to record the "size" of the invoices sampled.
A Poisson distribution could model these examples if the following conditions
are met:
· The
rate of defects per unit of space or time is the same for each item.
· The
number of defects observed in the items are independent of each other.
