Process parameters
overview
Process capability statistics are numerical measures of process capability - that is, they measure how capable a process is of meeting specifications. For a stable process, reliable estimates can be made of the various process parameters required for capability studies. The parameters used in estimating the indices differ based on the distribution used in the analysis. Use the table below as a guide:
Assumed distribution
Capability measures
Parameters estimates used
Normal (within analysis)
Potential capability
Process mean (X)
Within-subgroup standard deviation
Normal (between/within analysis)
Between/Within capability
Process mean (X)
Between/Within standard deviation
Normal (within and within/between analysis)
Overall capability
Process mean (X)
Overall standard deviation
Nonnormal
Overall capability
Process median (50th percentile)
Process spread (99.965th percentile - 0.135th percentile)
Based on the ISO method (the default) or the Minitab method.
