1 In the control chart dialog box, click Labels.
2 Click the Titles and Footnotes tab.
3 In Title, type the primary title, which is centered above the graph.
4 In Subtitle 1 and Subtitle 2, type the subtitles, which appear below the primary title. If you add a subtitle but do not add a primary title, the subtitle displays below Minitab's default title.
5 In Footnote 1, type the primary footnote, which appears at the bottom left of the graph.
6 In Footnote 2, type the secondary footnote, which appears below the primary footnote. Click OK.
