To define stages in your process, you must set up a column of grouping indicators. The indicators can be numbers, dates, or text. When executing the command, you can tell Minitab to start a new stage in one of two ways:
The column must be the same length as the data column (or columns, when subgroups are across rows).
1 In the control chart dialog box, click control chart Options.
2 Click the Stages tab.
3 In Define stages (historical groups) with this variable, enter the column which contains the stage indicators.
4 Under When to start a new stage, do one of the following:
5 If you like, use any dialog box options, then click OK.
