1 In
control chart dialog box, click Gen
Var Options.
Click the Limits tab.
2 Do
any of the following:
· Under Display additional confidence
limits at, enter one or more values or enter a column of values
in These percents.
Enter proportion values (between 0 and 1) or percent values (between 1
and 100).
· Under Place bounds on confidence
limits, check Lower
confidence limit bound, then type the lower confidence limit (greater
than 0).
· Under
limits, check Upper
confidence limit bound, then type the upper confidence limit (greater
than 0).
3 Click
OK.
