查看: 622|回复: 0
IEC 62561-5:2017 earth electrode inspection housings and earth electrode seals
管理员
发表于 2017-8-17 22:03:46 | 显示全部楼层 |阅读模式
IEC 62561-5:2017 Lightning protection system components (LPSC) - Part 5: Requirements for earth electrode inspection housings and earth electrode seals
IEC 62561-5:2017 specifies the requirements and tests for earth electrode inspection housings (earth housing) installed in the earth and for earth electrode seals.
Lightning protection system components (LPSC) can also be suitable for use in hazardous atmospheres. There are therefore additional requirements when installing the components under such conditions.
This second edition cancels and replaces the first edition, published in 2011. This edition constitutes a technical revision.
This edition includes the following major technical changes with respect to the previous edition.
- Testing requirements have been added for the sealing of earth electrode installed in or through watertight concrete.
Publication type        International Standard
Publication date        2017-07-28
Edition        2.0
Available language(s)        English/French
TC/SC        TC 81 - Lightning protectionrss
ICS        29.020 - Electrical engineering in general
91.120.40 - Lightning protection
Stability date          2025
Pages        33
File size        1300 KB
GMT+8, 2024-5-8 03:48 , Processed in 0.105408 second(s), 6 queries , Gzip On, Redis On.
