查看: 13565|回复: 9
游戏手柄验货不良中英文对照
发表于 2017-9-6 14:32:28 | 显示全部楼层 |阅读模式
missing choose color on carton        外箱漏勾颜色
carton broken        外箱破损
serial number on carton cracked        外箱条码裂开
carton poor shape        外箱未折到位缝隙大
no marking on carton        外箱无标示
gift box crushed        彩盒压烂或压皱
gift box illegible        彩盒背面文字印刷不良
missing sticker of serial number on gift box        彩盒无产品条码
gift box torn        彩盒撕裂
blister deformed        吸塑内托变形
blister too thin        吸塑薄、脆
blister uneven        吸塑材质不均有厚薄印
instruction sheet poor die-cut/non-bookbinding        说明书未装订或剪裁不良
instruction sheet wrong version        说明书版本错
missing instruction sheet        漏装说明书
dirt mark on USB wire         USB线脏污
USB wire abrasion        USB铁壳擦花
USB wire rust        USB铁壳有绣点
USB wire poor binding        USB主线扎线不良
foreign stuffing on USB wire        USB主线有异物
foreign tape on USB wire        USB主线有胶纸
abrasion mark on USB wire        USB主线有磨痕
dent mark on USB wire head        USB线头压印
scratch mark on USB wire head        USB线头刮伤
USB wire head deformed        USB线头变形
scratch mark on USB wire        USB主线线皮刮伤
contact plate come off        电池仓导垫片脱落
fastening battery        电池仓卡电池不易取出
USB part of USB-Micro USB converting cable deformed        充电线线头变形
Micro part of USB-Micro USB converting cable deformed        充电线Micro端变形
missing USB-Micro USB converting cable        充电线漏装
scratch mark on USB-Micro USB converting cable        充电线刮伤
metal shell of wireless receiver come off        接收器金属壳脱落
wireless receiver deformed        接收器变形
dirt mark on wireless receiver        接收器脏污
waggle noise        内有物异响
cosmetic defect of grip plastic        握把包胶外观不良
bubble grip plastic        握把包胶起包鼓起
poor assembly of grip plastic        握把包胶装配不良
scratch mark on grip plastic        握把包胶刮花
abrasion mark on grip plastic        握把包胶有磨痕
excessive flash on grip plastic        握把包胶有批峰
poor assembly of grip plastic        握把包胶凸起断差
poor assembly of grip plastic        握把包胶和壳料断差缝隙大
grip plastic scratch hand        握把包胶和壳料断差刮手
grip plastic scratch hand         包胶握把处刮手
offset between shells        正侧面弧线处上下壳断差刮手
tail part of grip plastic scratch hand        握把末端尖角处刮手
offset between shells        上下壳断差刮手
excessive gap between shells         上下壳缝隙偏大
poor assembly of shells        上下壳未装配到位缝隙大
color deviation between shells        上下壳有色差
motor wire trapped by shells        上下壳夹马达线
foreign stuffing trapped by shells         上下壳夹有异物
protective film remnan between shells        上下壳夹有保护膜
plastic remnan between shells        上下壳夹有胶丝
missing date code label        漏保用贴
inconsistent month of date code label        保用封贴月份不统一
date code label peel off        保用封贴翘起
date code label broken        保用封贴破损
missing date code        保用封贴标未标示日期
dirt mark on LB/RB-key        LB/RB脏污
lube smudge on LB/RB-key        LB/RB有油污
crack mark on LB/RB-key        LB键有裂纹
lube smudge on LT/RT-key        LT/RT键油污
missing letter on LT key        LT键没镭雕字体
missing anti-fake label        漏防伪贴
anti-fake label scratched        防伪贴刮花
anti-fake label crushed        防伪标皱
foreign materials in screw hole        螺丝孔有脏污
missing screw        漏打螺丝
wrong sticker of serial number        背贴序列号错误
poor sticker of serial number printing        背贴字母漏印
poor sticker of serial number printing        背贴印刷错误
poor sticker of serial number printing        背贴印刷不良
sticker of serial number illegible        背贴印刷不清晰
sticker of serial number damaged        背贴残缺
dirt mark on sticker of serial number        背贴脏污
sticker of serial number peel off        背贴翘
sticker of serial number torn        背贴撕裂
cut mark on sticker of serial number        背贴有划痕
sticker of serial number come off        背贴脱落
sticker of serial number wrinkled        背贴不平整
dust on shell        壳料表面灰尘
lube smudge on shell        壳料有油污
excessive flash on shell        壳料有披锋
burn mark on shell        壳料烫伤变形
scratch mark on shell        壳料刮花
dirt mark on shell        壳料脏污
white mark on shell        壳料有白色脏污
shell damaged        壳料碰伤
color deviation        壳料颜色与样品不一致
paint accumulated        壳料喷油不良表面积油
flow line on shell        十字键左下方有长气纹线
poor silk screen printing        丝印不良
double image        丝印重影
bottom shell yellow mark         白色底壳发黄
foreign tape on bottom shell        底壳有胶纸
poor bottom shell painting        底壳喷油不良
paint accumulated on bottom shell        底壳积油
key come off        按键脱落
white mark on shell of A-key        A键壳套发白
scratch mark on A-key        A键刮花
scratch mark on shell of B-key        B键外罩刮花
excessive flash on B-key        B键有披锋
joystick misaligned        蘑菇头歪
joystick's grip plastic peeling        蘑菇头包胶脱皮
joystick's grip plastic damaged        蘑菇头包胶残缺
holes on joystick's grip plastic        蘑菇头包胶有细孔
dirt mark on joystick's grip plastic        蘑菇头包胶有脏污
joystick's grip plastic cracked        蘑菇头包胶破裂
scratch mark on joystick's grip plastic        蘑菇头包胶刮花
dent mark on joystick's grip plastic        蘑菇头包胶有压印
abrasion mark on joystick's grip plastic        蘑菇头包胶擦伤
excessive flash on joystick's grip plastic        蘑菇头包胶有批锋
lube smudge on joystick's grip plastic        蘑菇头包胶有油污
scratch mark on joystick's ABS lining        蘑菇头内衬刮花
splay mark on joystick's ABS lining        蘑菇头内衬料花
white mark on joystick's ABS lining        蘑菇头内衬发白
burn mark on joystick        摇杆烫伤
dirt mark on D-pad        十字键脏污
wrong key assembly        十字键和摇杆互换功能键装配错误
dirt mark on BACK-key        BACK键有脏污
silk screen printing illegible        START键丝印模糊
poor silk screen printing        START键丝印不良
missing logo sticker        漏滴胶
logo sticker dislocated        滴胶装配移位
logo sticker damaged        滴胶破损
logo sticker uneven        滴胶不匀称
air bubble in logo sticker        滴胶有气泡
yellow mark on logo sticker        滴胶有白点发黄
poor logo sticker assembly        滴胶装配不良
logo sticker misaligned        滴胶贴歪
logo sticker uneven        滴胶厚度不一致
poor logo printing        LOGO印刷不良
dirt mark on logo-key        LOGO键脏污
poor laser mark of logo-key        LOGO键镭雕不全
poor laser mark of logo-key        LOGO键镭雕反
poor indicator lamp assembly        指示灯装配不良
white spot on indicator lamp coverage        透明灯罩有黑点
excessive flash on indicator lamp coverage        灯罩有批锋
dirt mark on indicator lamp coverage        灯罩脏污
indicator lamp coverage wrinkled        灯罩不平整
poor USB-Micro USB converting cable pulling and pluging        充电线难拔插
poor USB-Micro USB converting cable pulling and pluging        充电线插不进
cannot open        无法开机(电池无电)
cannot charge        无法充电
cannot charge        无法充电(充电线坏)
indicator lamp no light        关机状态下充电,指示灯不亮
indicator lamp no light        开机后指示灯不亮
inconsistent light        开机后指示灯亮度不一致
weak light        开机后指示灯灯暗
wrong light        充电时指示灯指示错误
USB-Micro port non-function        Micro接口不良无法识别
wired mode non-function        无线手柄的有线模式无法识别
poor wired mode function        无线手柄使用有线时过不了延长线
cannot open        有线手柄无法识别
poor contact        USB主线接触不良使用断线
cannot match and connect        无法配对连接
cannot recognize wireless receiver        接收器无法识别
no receiving        接收器连接不上
receiving int        接收器连接断线
wrong software version        固件版本不对
receiving int        时有时无接触不良
cannot shift mode        按LOGO键不能切换模式
wrong default mode        默认模式不对
key value auto work        模式自跳
key value auto work        充电时键值自亮
program crash        PS3有线模式掉程序
low voltage        低电
poor response        手柄功能反应迟钝
response linkage        功能连动
no light        炫光灯不亮
A-key noise        A键异响
A-key stick fast        A键卡键
poor A-key press feel        A键手感不良
firm A-key press        A键重压
poor B-key press feel        B键手感不良
B-key stick fast        B键卡键
firm X-key press        X键重压
poor X-key press feel        X键手感不良
Y-key stick fast        Y键卡键
firm Y-key press        Y键重压
poor Y-key press feel        Y键手感不良
inconsistent D-pad press feel        十字键手感不一致
poor D-pad press feel        十字键手感不良
firm D-pad  press        十字键重压
D-pad noise        十字键异响
D-pad's 45 degree press difficult        十字键45度难打
firm LB-key  press        LB键重压
LB-key value auto work        LB键自亮
LB-key stick fast        LB键卡键
poor LB-key press feel        LB键手感不良
LB-key noise        LB键异响
LB-key non-function        LB无功能
inconsistent press feel between LB and RB        LB/RB手感不一致
RB-key stick fast        RB卡键
poor RB-key press feel        RB键手感不良
firm RB-key  press        RB键重压
LT-key value auto work        LT键自亮
firm LT-key  press        LT键重压
poor RB-key press feel        LT键手感不良
LT-key stick fast        LT键卡键
LT-key value cannot return to zero        LT键不回零
LT-key non-function        LT键无功能
wrong assembly        按键装配错误(两个RT键)
inconsistent press feel between LT and RT        LT/RT键力度不一致
RT-key stick fast        RT键卡键
RT-key value auto work        RT键自亮
RT-key non-function        RT键无功能
poor RT-key press feel        RT键手感不良
RB-key noise        RT键卡顿异响
motor on constantly        左/右马达自震
motor non-function        左/右马达不震
motor noise        左/右马达异响
clearace        转轴虚位太大,电位器使用错误
joystick deformed        蘑菇头下压过限位转不顺畅,内部3D杆变形
joystick non-function        摇杆无功能
joystick value auto work        摇杆自跳
joystick non linear function        摇杆无轴功能
poor joystick linear function        摇杆左右打不到边
joystick value cannot return to zero        摇杆不归中
joystick non-function        摇杆转动无功能,掉程序
joystick noise        摇杆"唧唧"异响
poor joystick twirl        摇杆刮壳转动卡
poor joystick twirl        摇杆与面壳干涉,转不顺畅
poor joystick twirl        右摇杆批锋转不顺畅
poor joystick twirl        左摇杆有批锋摇杆转不顺畅
poor joystick press feel        摇杆下压无手感
poor joystick press feel        摇杆下压手感不良
firm BACK-key  press        BACK键重压
poor BACK-key press feel        BACK键手感不良
BACK-key non-funtion        BACK键无功能
START-key non-funtion        START键无功能
START-key value auto work        START键自亮
firm START-key  press        START键重压
poor START-key press feel        START键手感不良
START-key stick fast        START键卡键
LOGO-key stick fast        LOGO键卡键
firm LOGO-key  press        LOGO键重压
poor LOGO-key press feel        LOGO键手感不良
poor LOGO-key press feel        LOGO键无手感
LOGO-key non-funtion        LOGO键无功能
SHIFT-key non-funtion        按SHIFT键指示灯不变
CLEAR-key non-funtion        CLEAR键无功能
poor TURBO-key press feel        TURBO键手感不良
重庆市 九龙坡区
发表于 2017-9-6 16:26:16 | 显示全部楼层
发表于 2017-9-7 08:52:34 | 显示全部楼层
发表于 2017-9-7 16:51:53 | 显示全部楼层
发表于 2018-8-25 12:57:29 | 显示全部楼层
发表于 2020-6-3 13:17:56 | 显示全部楼层
谢谢分享!!!!
发表于 2020-6-4 00:10:50 | 显示全部楼层
发表于 2020-6-8 11:44:15 | 显示全部楼层
发表于 2021-4-29 11:07:09 | 显示全部楼层
发表于 2023-10-8 22:58:17 | 显示全部楼层
GMT+8, 2024-5-3 02:21 , Processed in 0.067839 second(s), 5 queries , Gzip On, Redis On.
