查看: 749|回复: 0
IEC 62822-3:2017 0 Hz to 300 Hz Part 3: Resistance welding equipment
发表于 2017-9-24 15:02:38 | 显示全部楼层 |阅读模式
IEC 62822-3:2017 applies to equipment for resistance welding and allied processes designed for occupational use by professionals and for use by laymen.
This document specifies procedures for the assessment of human exposure to magnetic fields produced by resistance welding equipment. It covers non-thermal biological effects in the frequency range from 0 Hz to 10 MHz and defines standardized test scenarios.
GMT+8, 2024-4-28 17:02 , Processed in 0.021413 second(s), 6 queries , Gzip On, Redis On.
