查看: 558|回复: 0
IEC 60893-3-6:2003+AMD1:2009+AMD2:2017 rigid laminated sheets based on silicone
发表于 2017-9-24 15:06:19 | 显示全部楼层 |阅读模式
IEC 60893-3-6:2003+A1:2009+A2:2017 gives the requirements for industrial rigid laminated sheets for electrical purposes based on silicone resins and different reinforcements. Applications and distinguishing properties are given. Materials which conform to this specification meet established levels of performance.
However, the selection of a material by a user for a specific application should be based on the actual requirements necessary for adequate performance in that application and not based on this specification alone.
In this revision of the IEC 60893 series of specifications, new material types have been included, changes have been made to the property requirements of some existing types, a new method for testing permittivity and dissipation factor has been added, and all non-specification data for each type has been MOVed to a new Part 4 document - IEC 60893-4: Typical values. This consolidated version consists of the second edition (20013, its amendment 1 (2009) and its amendment 2 (2017).
Therefore, no need to order amendment in addition to this publication.
GMT+8, 2024-5-3 00:34 , Processed in 0.026614 second(s), 5 queries , Gzip On, Redis On.
