查看: 611|回复: 0
IEC 62677-1:2017 Heat shrinkable low and medium voltage moulded shapes
发表于 2017-10-15 18:20:17 | 显示全部楼层 |阅读模式
IEC 62677-1:2017 is applicable to heat shrinkable low and medium voltage moulded shapes in a range of configurations and materials suitable for insulation, environmental sealing, mechanical protection, electrical conductance, anti-tracking and strain relief for power cable terminations, joints and stop ends. It specifies the test methods and material requirements.
The most commonly available shapes are as shown in the Annex A. Materials which conform to this document meet established levels of performance. However, the selection of a material by a user for a specific application will be based on the actual requirements necessary for adequate performance in that application and will not be based on this document alone.
These moulded shapes are designed to be used in low and medium voltage cable accessories and as such electrical performance will be proven as part of the assembly.
Examples of this are described in EN 50393, HD 629.1 and IEC 60502-4.
GMT+8, 2024-5-2 13:51 , Processed in 0.021592 second(s), 5 queries , Gzip On, Redis On.
