查看: 537|回复: 0
IEC 62677-2:2017 Part 2: Methods of test
发表于 2017-10-15 18:20:31 | 显示全部楼层 |阅读模式
IEC 62677-2:2017 gives methods of test for heat shrinkable low and medium voltage moulded shapes in a range of configurations and materials suitable for insulation, environmental sealing, mechanical protection and strain relief for connector/cable terminations and multi-way transitions.
The tests specified are designed to control the quality of the moulded shapes but it is recognized that they are designed to be used in low and medium voltage cable accessories and as such electrical performance will be proven as part of the assembly. Examples of this are described in EN 50393, HD 629.1 and IEC 60502-4.
GMT+8, 2024-4-27 22:58 , Processed in 0.030877 second(s), 6 queries , Gzip On, Redis On.
