查看: 714|回复: 0
IEC 60793-1-47:2017 Measurement methods and test procedures - Macrobending loss
发表于 2017-10-15 18:21:50 | 显示全部楼层 |阅读模式
IEC 60793-1-47:2017 establishes uniform requirements for measuring the macrobending loss of single-mode fibres (class B) at 1 550 nm or 1 625 nm, category A1 multimode fibres at 850 nm or 1 300 nm, and category A3 and A4 multimode fibres at 650 nm, 850 nm or 1 300 nm, thereby assisting in the inspection of fibres and cables for commercial purposes.
This document gives two methods for measuring macrobending sensitivity:
- Method A – Fibre winding, pertains to class B single-mode fibres and category A1 multimode fibres.
- Method B – Quarter circle bends, pertains to category A3 and A4 multimode fibres.
For both of these methods, the macrobending loss can be measured utilizing general fibre attenuation techniques, for example the power monitoring technique (see Annex A) or the cut‑back technique (see Annex B).
Keywords: macrobending loss of single-mode fibers
GMT+8, 2024-5-2 17:48 , Processed in 0.023849 second(s), 5 queries , Gzip On, Redis On.
