查看: 660|回复: 0
IEC 60730-2-13:2017 Particular requirements for humidity sensing controls
发表于 2017-10-15 18:22:16 | 显示全部楼层 |阅读模式
IEC 60730-2-13:2017 applies to automatic electrical humidity sensing controls for use in, on or in association with equipment, including controls for heating, air-conditioning and similar applications. The equipment may use electricity, gas, oil, solid fuel, solar thermal energy, etc. or a combination thereof.
This Standard is applicable to automatic electrical humidity sensing controls forming part of a building automation control system within the scope of ISO 16484.
This standard also applies to automatic electrical humidity sensing controls for equipment that may be used by the public, such as equipment intended to be used in shops, offices, hospitals, farms and commercial and industrial applications.
This standard DOEs not apply to automatic electrical humidity sensing controls intended exclusively for industrial process applications unless explicitly mentioned in the equipment standard.
GMT+8, 2024-5-7 11:42 , Processed in 0.023228 second(s), 6 queries , Gzip On, Redis On.
