查看: 693|回复: 0
IEC 62841-3-14:2017 Particular requirements for transportable drain cleaners
发表于 2017-10-15 18:22:39 | 显示全部楼层 |阅读模式
IEC 62841-3-14:2017 applies to transportable drain cleaners. The rated voltage is not more than 250 V for single-phase a.c. or d.c. tools, and 480 V for three-phase a.c. tools. The rated input is not more than 3 700 W.
The limits for the applicability of this standard for battery tools are given in Annex K.
This standard deals with the hazards presented by tools which are encountered by all persons in the normal use and reasonably foreseeable misuse of the tools. Hand-held electric tools, which can be mounted on a support or working stand for use as fixed tools without any alteration of the tool itself, are within the scope of this standard and such combination of a hand-held tool and a support is considered to be a transportable tool and thus covered by the relevant Part 3.
Drain cleaners are also known as pipe cleaners.
GMT+8, 2024-5-8 08:40 , Processed in 0.066196 second(s), 7 queries , Gzip On, Redis On.
