查看: 11000|回复: 3
AS/NZS 3112:2011《Approval and test specification—Plugs and socket-outlets》
发表于 2017-11-2 18:40:22 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
This Standard specifies essential safety requirements for plugs and socket-outlets, as defined in Clause 1.4, intended for use at extra low or low voltages and a rated current not exceeding 32 A for household or similar purposes. (For extra low voltage plugs and socket-outlets, see Appendix E.)
This Standard DOEs not provide guidance on the following:
(a) Appliance couplers (see AS/NZS 60320.1).
(b) Installation couplers (see AS/NZS 3131:1995 or AS/NZS 61535.1).
(c) Plugs, socket-outlets and couplers for general industrial applications (see AS/NZS 3123).
(d) Plugs and socket-outlets for MOVeable appliances (see AS/NZS 3131).
下载链接:https://pan.baidu.com/s/1qX95NMO
109
发表于 2018-3-4 12:23:16 | 显示全部楼层
发表于 2022-3-5 09:05:24 | 显示全部楼层
发表于 2022-3-19 19:33:19 | 显示全部楼层
GMT+8, 2024-5-9 15:12 , Processed in 0.074168 second(s), 6 queries , Gzip On, Redis On.
