IEC 61196-1-206:2017 Coaxial communication cables - Part 1-206: Environmental test methods - Climatic sequence
IEC 61196-1-206:2017 specifies the method of test to determine the stability of transmission performance of a finished RF coaxial cable when subjected to a set of temperatures, temperature changes, and humidity stresses that would accelerate exposures observed in storage and transportation.
It utilizes the test method of IEC 60068-2-61: Environmental Testing - Part 2-61: Test methods - Test Z/ABDM: Climatic sequence, which replaces the thermal cycle test.
