查看: 700|回复: 0
IEC 62341-6-3:2017 OLED displays Part 6-3: Measuring methods of image quality
发表于 2017-11-18 22:00:29 | 显示全部楼层 |阅读模式
IEC 62341-6-3:2017 Organic light emitting diode (OLED) displays - Part 6-3: Measuring methods of image quality
IEC 62341-6-3:2017(E) specifies the standard measurement conditions and measuring methods for determining the image quality of organic light emitting diode (OLED) display panels and modules.
This second edition cancels and replaces the first edition published in 2012. This edition constitutes a technical revision.
a) the measuring method for viewing angle has been modified. Measurement of the half luminance angle, gamma distortion, and directional colour variation is added;
b) measurement method for colour characteristics is added;
c) additional explanation is added in static image resolution clause;
d) MOVing image resolution clause has been moved to Annex B.
GMT+8, 2024-5-4 22:01 , Processed in 0.022133 second(s), 5 queries , Gzip On, Redis On.
