查看: 673|回复: 0
IEC 60061:2017 DB Lamp caps and holders together with gauges for the control ...
发表于 2017-11-18 22:01:42 | 显示全部楼层 |阅读模式
IEC 60061:2017 DB Lamp caps and holders together with gauges for the control of interchangeability and safety - 12-month subscription to online database comprising all parts of IEC 60061.
The database has been updated following the publication of Corrigendum 1 of Amendment 56 to Part 1.
It contains the recommendations of the IEC in regard to lamp caps and holders in general use, together with relevant gauges, with the object of securing international interchangeability. The standard consists of four parts. Part 1: Lamp caps, Part 2: Lampholders, Part 3: Gauges, Part 4: Guidelines and general information. There are some 900 standard sheets in PDF format that can be accessed individually from the various indexes and through the search facility.
Following years subscription CHF 220.-
GMT+8, 2024-5-5 01:40 , Processed in 0.020778 second(s), 5 queries , Gzip On, Redis On.
