查看: 17584|回复: 23
Minitab里Pooled standard deviation(合并标准差)的计算公式和解释
管理员
发表于 2017-8-4 19:38:14 | 显示全部楼层 |阅读模式
Pooled standard deviation(合并标准差) is a way to find a better estimate of the true standard deviation given several different samples taken in different circumstances where the mean may vary between samples but the true standard deviation (precision) is assumed to remain the same. It is calculated by Pooled standard deviation.
where sp is the pooled standard deviation, ni is the sample size of the i'th sample, si is the standard deviation of the i'th sample, and k is the number of samples being combined. n−1 is used instead of n for the same reason it may be used in calculating standard deviations from samples.
945
管理员
 楼主| 发表于 2017-8-4 19:56:08 | 显示全部楼层
4种标准差σ的计算方法:简易标准差,Rbar/d2,Sbar/C4和Minitab中的Pooled standard deviation(合并标准差)
http://www.pinzhi.org/forum.php?mod=viewthread&tid=576
发表于 2017-8-7 10:21:09 | 显示全部楼层
谢谢分享。。。
发表于 2017-8-21 10:15:46 | 显示全部楼层
发表于 2017-8-30 16:54:58 | 显示全部楼层
thanks
发表于 2017-10-27 19:26:38 | 显示全部楼层
牛逼
发表于 2017-11-12 12:01:14 | 显示全部楼层
发表于 2017-11-14 12:06:42 | 显示全部楼层
发表于 2017-11-16 11:27:54 | 显示全部楼层
看着好难呀!
发表于 2017-12-4 08:48:36 | 显示全部楼层
GMT+8, 2024-4-27 18:47 , Processed in 0.040228 second(s), 6 queries , Gzip On, Redis On.
