查看: 2756|回复: 4
Wi-Fi Modules FCC, CE, Japan Giteki 认证 (Regulatory Approvals)
管理员
发表于 2017-8-4 21:26:16 | 显示全部楼层 |阅读模式
认证检测
分类: 电子电气&数码家电(IT)
下面是一个 Wi-Fi Modules 获得FCC, CE, Japan Giteki 认证 (Regulatory Approvals) 案例,里面还包括相应的标准和简单的信息,仅供参考。
The RTX4100/RTX4140 Wi-Fi Modules are small form-factor, single stream, 802.11b/g/n Wi-Fi modules with on-board low power application processor. It is targeted at applications that send infrequent data packets over the network. Typically, these 802.11 applications will place a higher priority on system cost, power consumption, ease of use, and fast wake-up times as compared to high throughput.
The RTX4100/RTX4140 have received regulatory approvals for modular devices in the United States (FCC) and Canada (IC), regulatory approvals in Europe (ETSI), and regulatory approval in Japan (Giteki). The modular approval allows the integrator to place the RTX4100/RTX4140 using either the internal antenna or an approved antenna inside a finished product without having to perform costly regulatory testing.
The requirements the integrator must fulfil to use modules without additional testing are listed in this Application Note.
附件是rar格式,解压缩后,里面有个pdf格式的文件即是。
RTX4100_Application_Note_Regulatory_Approvals_AN4.pdf
RTX4100_Application_Note_Regulatory_Approvals_AN4.zip
271.17 KB, 下载次数: 5
发表于 2018-5-3 17:03:51 | 显示全部楼层
感谢分享。
发表于 2019-8-30 15:12:47 | 显示全部楼层
谢谢楼主的分享!!!!!
发表于 2020-2-17 14:02:26 来自手机 | 显示全部楼层
发表于 2022-3-29 19:40:21 | 显示全部楼层
GMT+8, 2024-5-9 17:06 , Processed in 0.040491 second(s), 7 queries , Gzip On, Redis On.
